Go Back   MBWorld.org Forums > Mercedes-Benz SLR & SL Roadsters > SL-Class (R230)
SL-Class (R230) 2003 on: Discussion on the SL500, SL550, SL600
Welcome to MBWorld.org!
Welcome to MBWorld,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
LinkBack Thread Tools Search this Thread Rate Thread Display Modes
Old 11-08-2007, 01:35 PM   #1
StephenK's Avatar
Drives: 2006 SL600, 2001 S500, 1996 SL320
Device Unavailable - Command Unit
In my 06 SL600 today when starting the car the command unit comes on, but then instead of showing anything, like a radio station or CD or Map, a small message comes on and says "DEVICE UNAVAILABLE" and then the unit shuts off.
In the past after leaving the car sit for several days I would get a message in the instrument cluster saying convenience items unavailable, but then after running the car for a few minutes that would go away and items like the steering wheel moving up and down would work again.
Any ideas????
To remove this ad, register today or login if you already are registered!
StephenK is offline   Reply With Quote
Old 11-08-2007, 02:22 PM   #2
Murtaza's Avatar
Drives: 08' M6
It could be your battery/alternator.
My car died a couple weeks ago and right before it did, I got that message. My alternator was out...
__________________
'08 M6 Alpine White on Black | RPi GT Exhaust Sections 1, 2, 3 | RPi Scoops + block off plates / BMC filters
'06 SL55 030 Black on Berry Red | 20" HRE 542R w PS2's | Resonator Delete (gone)
'06 SL500 Iridium Silver on Berry Red |Straight Piped | Quad Tips | 8k heads/fogs | SmarTop Roof Control Mod | Blacked out tails / decklid spoiler / badges / fins - Work done by HMS
'06 E350 | Stock workhorse (gone)
Murtaza is offline   Reply With Quote
Old 11-08-2007, 03:55 PM   #3
StephenK's Avatar
Just went out
Just went out to run some errands, got in the car, started it up and the command unit was up and running, noticed the clock on the dash was working too. Maybe the convenience battery was low, not sure, but oh well for now it is working again.
Old 11-09-2007, 09:02 AM   #4
Scotsman's Avatar
Drives: 2005 SL500, 2007 R350 Sport
I've had the "convenience functions temporarily unavailable" quite a few times but never "DEVICE UNAVAILABLE" and shutting down. COMAND was always available. Doesn't sound like the same thing to me.
If it happens again try your heated seat - if the led's on the seat switch flash the battery's low. That's what happens when I get "convenience functions temporarily unavailable".
Scotsman is offline   Reply With Quote
Old 11-11-2007, 09:12 PM   #5
Drives: e55
when battery voltage gets low the car will go into proitization (sp) and consumers will go offline.. if your having comand problems that can be a whole diferent story. you may have a problem with your fiber optics or the MOST RING.
MBELITE is offline   Reply With Quote
Old 11-11-2007, 09:56 PM   #6
BMS
Drives: SL55 2004
Had dealer install Mercedes trickle charger in trunk so that all I have to do is plug it into wall when the car sits more than a day or two and it ended those kinds of problems
BMS is offline   Reply With Quote
Old 12-16-2007, 11:51 AM   #7
Drives: 2004 SL500
My 3 year old SL500 with 11,000 miles on the clock comes up with "Convenience functions temporarily unavailable" whenever the car is left more than 18 hours without a drive. Within 5 miles the battery recharges so it all kicks back in again. If I leave it a week, you even have to use the metal bit of the key to get into the car.
I took it to Mercedes Benz main dealers 2 weeks ago thinking they would fit a new battery but was told that they had detected a drain on the battery but didn't know where it was coming from. (They thought it might be a fault with the EIS, or maybe with the immobiliser)
I took it back in for further tests this week and was then told that they could not detect any fault, and that the battery was fine, and that they had just recharged the battery and that everything should now be fine.
2 days later the "convenience functions-----etc" is coming back on again.
Any ideas what is going on?
trident-7 is offline   Reply With Quote
Old 12-17-2007, 05:31 AM   #8
Scotsman's Avatar
I had the exact same problem. Found out it was the telephone wiring. It was draining the battery even with no phone connected.
Only get that warning if the car's not driven for 2 weeks+ now.
Tags
55, benz, command, convenice, convenience, device, functions, mercedes, message, r350, sl, sl500, sl55, temporarily, unavailable
Search this Thread:
Advanced Search
Display Modes Rate This Thread
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Advertise on MBWorld.org - Terms of Service - Privacy Policy - Jobs
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.0
Copyright © 2001-2008 InternetBrands, Inc. / MBWorld.org. All Rights Reserved.
