Tranny Problem Break Through!!!
CHECK THIS OUT... ALL YOU C220 OWNERS LISTEN up.
Have had a tranny problem for 2 years.
Similair stuck shifting to all repots.
I had to jump start my 1998 528 with my trusty 94 c220. i made the mistake of cross wiring the cables. I burned the abs fuse. (btw) is located away from the other fuses.
Two things happened:
Odometer stopped logging speed and mileage.
Transmission was shifting flawlessly!!!
Drove it for a couple of days like this.,.. very smooth shifting.
As soon as I replaced that fuse my transmission had trouble shifting from 2nd to 3rd.
Is is possible that a faulty abs speed sensor could cause shifting problems???
Any Mechanics out there aware of the realtionship between abs to tranny?
