Solution For The Transmission Problem! I Sloved It!!!
Old 12-14-2004, 12:12 AM
ezeneli's Avatar
1997 C36
You heard right I have ordered the 5spd tranny from a 1996 C280 with all parts needed for conversion. All parts from europe. Parts are as follows
1. 5spd non-auto tranny rated for 320HP
2. Pedals (clutch and brake)
3. Propeller shafts (drive shafts)
4. All fluid lines
5. Flywheel
6. New Clutch
7. All nuts and bolts.
No more tranny problems for me. I paid $1150 for the tranny and all parts. Shipping was another $600 arm and a leg for shipping. And $240 for new clutch w/ shipping. It will take 3 weeks to arrive. The labor is goning to be $600 for all. This is going to be an easy conversion.
If any of you are intrested let me know. I can get all parts needed for you. This is the answer to all of your tranny problems. This conversion works for all C280 and C36 cars that I know of. In europe most C280s are 5spd and some C36s all share the same tranny.
If you look at your brake resivior you can see a spout on the side of it that is closed off that is for the slave cylinder in the clutch pedal assy. And look behind the brake booster you can see black plugs were the lines go you car is all ready for the conversion, so dont let a mechanic tell you its a hard job to do its not about 10 hours of labor its in there service books. The labor for the tranny, clutch and shafts is 6 hours remove and install and the pedal assy. is 4 hours.
Old 12-14-2004, 12:48 AM
speedybenz's Avatar
AMG C43, 1999
Cool, Keep us informed on your progression. I would like to do something like that for my C43.
Jeff
Old 12-14-2004, 04:53 AM
KenzBenz's Avatar
1995 C36
keep us updated. if my tranny ever goes out, this can be a solution
Old 01-01-2005, 10:01 PM
M104-AMG's Avatar
W124 E36T AMG; W124 500E
I definitely want to do this . . .
:-) neil
Old 01-02-2005, 06:22 AM
steve s's Avatar
1996 C36 AMG, 1995 Volvo 850 Turbowagon
cool, i am curious...is there a tcu for the automatic? if so, did u simply just remove it? the 97 had a different engine management...was it drivebywire or not?
Old 01-03-2005, 08:13 AM
ezeneli's Avatar
1997 C36
Just got good news tranny will be here jan 11 I will let you guy know about install soon
Old 01-04-2005, 08:59 PM
saturnstyl's Avatar
An ME control unit will need to be programmed for the lack of the transmission computer and electronic selector lever. This tranny likely will not hold the V8 models.... Too much torque.
Old 01-10-2005, 01:01 AM
040mercedes's Avatar
C280
Ooohh....I also want to see this. I'll agree with everyone when they say "keep me posted" I want a manual in my 202 badly. Let me know how you handle the electronics on this one.
Old 01-21-2005, 10:12 PM
ezeneli's Avatar
1997 C36
Click here for details on conversion
Old 05-03-2009, 11:45 AM
UK-J's Avatar
190 2.5-16V
I would like to ask , how you solved the flywheel problem.
I too am having built a 190 with AMG C36 engine & manual Getrag from a 320 CE-24V.
We are using a dual mass flywheel , and although we can start the engine , and have a good tickover, we still cannot rev the engine.
We think that this is because the magnet on the flywheel is not in the correct position.
Do you have an exact position for the magnet, or is it possible to direct me to where I can find the information.
I am from London, England , and a 4000+ poster on the excellent mercedes190.co.uk site.
However, as the only C36 engined 190 in the uk is mine, there is not a whole lot of info hereabouts.
Can you guys help a Brit?
I also own an original 2.5-16V which is my trackday car.
Many thanks,
Jeremy
Old 05-03-2009, 10:17 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
What year engine management and flywheel are you using? There are two different flywheels used on the l6 motors. pre '97 and '97 and later are different. 60-2 teeth on the later and 3 magnets on the earlier.
Old 05-03-2009, 10:25 PM
C43AMG's Avatar
98 Black C43 , 08' ML320 CDI ,11 E63
You realize this thread is 4-1/2 years old?
Old 05-04-2009, 03:39 AM
UK-J's Avatar
190 2.5-16V
Yup, thats how desperate we are
We have searched every thread on every M-B forum the world over
Jeremy
Old 05-04-2009, 03:42 AM
UK-J's Avatar
190 2.5-16V
I will have the flywheel info for you later today.
We are using an ECU from a '94 320-24V
We binned the loom from the original engine as we didn't get the D.A.S. with it. and started again, Knowing that we did not need most of it anyway, and used one from a 320-24V
Jeremy
Old 05-06-2009, 07:47 AM
UK-J's Avatar
190 2.5-16V
In all this excitement about AMG C36 engined 190's with manual gearboxes being unique, I've just remembered that they are not quite.......................
Brabus made some 190 3.6S lightweight cars with manual gearboxes.
Are there any in the US???
Jeremy
Quick Reply: Solution For The Transmission Problem! I Sloved It!!!
