FYI: '01 E430 Bose stereo speaker wiring colors...
Old 11-15-2004, 08:13 PM
Little's Avatar
2001 E430 4matic
If anyone was interested, i've found all the color codes for each speaker in my benz last nite. This is at the amp. They go a lil something like this:
Left Front= Green/Brown-Green
Right Front= Black/ Brown-Black
Left Rear= Pink/ Brown-Pink
Right Rear= White/ Brown-White
Left Sub = Purple/ Brown-Purple
Right Sub= Blue/ Brown- Blue
Constant power is 10ga Red with Blue stripe
Didn't get to check anything else out
Proturner (05-03-2018)
Old 11-17-2004, 09:38 AM
diffuzi0n's Avatar
e320 99
good info there. Do you know anything about PAC OEM-2 from crutch field. amp to head unit converter.
Old 11-17-2004, 04:27 PM
Little's Avatar
2001 E430 4matic
Nah never heard of it. I just picked up an AudioControl LC6 Concert Series Six Channel Line ouput Converter. It's a pretty sweet unit, with outputs for subs, front and rear. Also has signal sensing so no need for an amp turn-on. I'm gonna be replacing the front factory speakers with Focals components and power them with my Zapco Studio 300 and then tap into the sub outputs for my 4- 12" JL Subs with Zapco Studio 500 powering them. I'll let eveyrone know how things turn out.
Old 11-18-2004, 02:07 AM
rob_fed's Avatar
W204 C300 2010
Here is more data from www.the12volt.com
1999 Mercedes E-Class Stereo Information:
Constant 12V+ Red/White
Switched 12V+ Black/Yellow
Ground Brown
Illumination n/a
Dimmer n/a
Antenna Trigger Blue/White
Antenna Rear Window
Front Speakers 5 1/4" Doors
Left Front (+) Green
Left Front (-) Brown/Green
Right Front (+) Black
Right Front (-) Brown/Black
Rear Speakers 5 1/4" Door
Left Rear (+) Pink
Left Rear (-) Brown/Pink
Right Rear (+) White
Right Rear (-) Brown/White
Old 11-18-2004, 08:52 AM
Elvis Presley's Avatar
You may not need the converter Little
The Zapco amp probably has a balanced input, and depending on your headunit, a simple 6 pin mini din plug can be used to connect the 2. I have been successful using soundstream amps. I have the pin out for the e320 wagon with Bose system if you are interested. It may be the same plug.
Old 11-18-2004, 02:21 PM
Little's Avatar
2001 E430 4matic
the zapcos do in fact have a balanced input. I'm gonna use the factory head unit though, not my eclipse one.
Old 11-18-2004, 11:42 PM
Scrap the converter
I spoke with Zapco, they told me that there balanced input supported up to 16 volts. I spoke with a Bose service center in St. Louis that told me the radio output was 600 milivolt or .6 volts. You may not have enough drive for the amp, but it would be worth your effort to try connecting the factory head unit. It worked really well with mine. The Bose amp is so horrible that I would hate to see you use it (in this case you are using it as a line driver) unless necessary. My car also has a trigger out 12 volts to turn on the amp. Keep me posted as I am using the factory head unit.
I am waiting impatiently for the new ICruz from Monster Cable. As I do not have a cd changer, this looks cool. As I understand it, the device acts as an interface for the fiber cd connector. The neat part, it emulates a cd changer so it recognizes the first 6 folders as cd's and identifies the first 99 files as songs on the cd.
Old 06-15-2012, 04:32 PM
psakthik's Avatar
2002 ML320 & 2006 BMW 330i
Hi Little,
I bought the Bose amp to replace, don't know which pin at the amp goes to which speaker. Can you give the Speak wire to Amp pin connection details?
Pals
Old 06-19-2012, 10:54 AM
renault12ts's Avatar
W215 CL500 2005
Great info OP...thanks.
Old 11-18-2020, 04:00 PM
Schaffer's Avatar
Benz e 430 awd
Could you send me that pin out plz schafeazy91@gmail.com
could you an me that pin out plz schafeazy91@gmail.con
Quick Reply: FYI: '01 E430 Bose stereo speaker wiring colors...
