What does the w211 really produce at the crank? 493hp?
Received 1,886 Likes
I've heard and read differing opinions on this. Some say it's underrated, whilst others think it's dead-on.
Re: What does the w211 really produce at the crank? 493hp?
Originally posted by E55 POWER
Mine did 400rwh with a bad water pump.
400x1.2=480 to the crank, I am not sure about the conversion. But it's what I've heard.
Regards,
E55 POWER
Regards,
E55 POWER
Evosport dyno'd a stock E55 - there's a thread about it on the forums about it - I believe they dyno'd at around 520 crank.
E55, F550, S600 Ducati 999
Evosports dyno numbers tend to be a little higher than seen on other dynos. The E55's produce around 15rwhp less than the S/SL55's on average from what I have seen. I think the numbers are dead on.
As for what the E55 really puts out at the crank.... all that matters is what it puts out the rear wheel. Pick a drivetrain loss % and you can pretty much make it whatever you want. I usually use 15 - 17%, but I don't think anyone on this board knows what it really is
It's very impressive, nonetheless.
Thanks for the informative replies.
Originally posted by dgussin1
Is this dyno sheet for a stock E55K? The torque is 586 lb/ft when converted to crank, using 18%. Is the torque that underrated, too?
Super Moderator
Using a 18% loss factor,
422.7 RWHP equates to 515 Crank HP.
481.3 RWTQ equates to 586 Crank TQ.
RWHP / 82 * 100 = x
I have been told DynoJet's sometimes show approx 10% greater #'s than in reality.
RWHP / 82 * 100 = x
