C230 Door Handle Removal Instruction
Old 05-13-2003, 09:21 PM
20FHK02's Avatar
2002 C230 Coupe
Post C230 Door Handle Removal Instruction
The stealer is quoting me ridiculous price for the colored door handle installation, so I decide to investigate how difficult it really is to get the job done. It turned out that, with my extremely slow pace and including documenting the entire process, it only took 15 min!! Here is how...
Step 1: (Start with the driver side) Peel off about 2 pins from the door weather strip to reveal the access hole. Then use a T-20 torx driver to release the screw that holes the IR receiver piece - WARNING: do NOT immediately remove the screwdriver as the screw may fall off!
foxhhh299 (09-11-2016)
Old 05-13-2003, 09:23 PM
20FHK02's Avatar
2002 C230 Coupe
Step 2: Use masking tape to hold the screwdriver in place, so that you can continue the process without worrying the screw falling off.
Old 05-13-2003, 09:26 PM
20FHK02's Avatar
2002 C230 Coupe
Step 3: Carefully pull out the IR sensor/lock assembly and unclip the sensor.
Old 05-13-2003, 09:30 PM
20FHK02's Avatar
2002 C230 Coupe
Step 4: Hold the screwdriver, and tape the tail of the screw to secure it. Now you can remove the screwdriver. Then slide the door handle out in the order shown.
Old 05-13-2003, 09:33 PM
20FHK02's Avatar
2002 C230 Coupe
Step 5: Slightly pry the 3 hooks of the cap to remove the the lock and IR sensor.
Old 05-13-2003, 09:36 PM
20FHK02's Avatar
2002 C230 Coupe
Step 6: IR sensor/lock cap removed.
Old 05-13-2003, 09:39 PM
20FHK02's Avatar
2002 C230 Coupe
Step 7: (Passanger side) Repeat the procedures to remove the IR sensor assembly and the handle piece. Remember to tape the tail of the fastening screw first before removing the screwdriver!
Old 05-13-2003, 09:43 PM
20FHK02's Avatar
2002 C230 Coupe
Step 8: There is no lock on the passanger side. Use a flat head screwdriver to pry off the spring holding the IR sensor to the cap.
* JOB DONE *
Old 05-13-2003, 09:47 PM
20FHK02's Avatar
2002 C230 Coupe
Installation tips: Make a hook using a steel wire to pull the door latch (inside the door, brass color) out while putting the door handle back, it makes the job a lot easiler! And, use some blue loctite for the screws.
Old 05-13-2003, 10:31 PM
GJR
GJR's Avatar
2002 S430
Excellent work! Thanks for taking the time to post this. It will definitely be my next modification! Now, if I could trouble you a bit more and ask you for the part numbers (my dealer's parts guy didn't know exactly which parts I'd need). I have Alabaster White also. Thanks!
Old 05-14-2003, 12:32 AM
20FHK02's Avatar
2002 C230 Coupe
I didn't buy the colored door handles though so I don't know the part numbers for those... I'm going to paint the grill this weekend and since the handles are so easy to do I may paint them as well.
I think if you tell the dealer those are the door handles for the Alasbaster White with C7 package, they can get you the right parts. They have the entire door assembly diagram, so when in doubt just tell them to fax you the diagram.
Old 05-14-2003, 01:16 AM
KWiK's Avatar
2002 C230 : 2007 C230
so how much did the dealer want for the 15 minutes of work?
Old 05-14-2003, 01:56 AM
20FHK02's Avatar
2002 C230 Coupe
The quoted shop hour is 1.5 hours, same as what I was charged for the 15 min CD changer installation - $165! I'm getting smarter so I won't take their bait this time.
Old 05-14-2003, 08:57 PM
DaBeze's Avatar
I changed mine out about 3 weeks ago. Bought them through Steve (MBenzNL). Great price, great mod, he even installed them for me!!!
A must have if you were dumb enough to get the car without C7 (or because it wasnt available)
Old 05-30-2003, 08:28 AM
gmabm's Avatar
How much did you paid for the handles? Sedan or Coupe?
A local paint shop wanna charge me US$60 for my Coupe's handles.
I am thinking to buy new or paint it instead...
Thanks.
Old 01-27-2004, 05:51 AM
jigga619's Avatar
2002 C230
Does Steve charge to come out and install?
Old 01-27-2004, 04:54 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Steve will be here in So Cal Next Month...If You want them or any other item..contact him asap!
Old 01-27-2004, 09:13 PM
PoonerElRay's Avatar
2017 GLA 250 4Matic
Those are really nice photos. What camera did you use to take those? I have the Canon 300D aka Digital Rebel.
Old 01-27-2004, 11:30 PM
20FHK02's Avatar
2002 C230 Coupe
A plain old Canon A40.
Old 09-02-2004, 02:28 AM
Almost a Member!
mic230coupe's Avatar
Door Handle Install Pics
Hello,
Is there any way you can email me the pics of the door handle install. I had copied the link on mbworld and now the pics are not visable anymore. I finally got the door handles from the dealer and those pics were very helpful. P lease email me at mic230coupe@msn.com when you have time. Thank you very much for your time and response. Take care.
Mike
Old 09-02-2004, 12:57 PM
nicedeboy's Avatar
Missing my beloved Benz
Hey, I just bought a set of torx drivers for my cell phone case replacment! My SL56 phone was made in germany just like the car. LOL
Old 09-02-2004, 04:07 PM
Saprissa's Avatar
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
if you searched, you didn't search hard enough....
Check this thread for pictures....
https://mbworld.org/forums/c-class-w203/73133-painted-door-handle-cap-part-no.html
Let me know if you don't get the pictures from 20FHK02. I have them in a 5 MB zip file if you still need them.
Old 09-03-2004, 12:39 AM
20FHK02's Avatar
2002 C230 Coupe
I did email out but it didn't get through, don't know why... I'll try to shrink down the size and post here for other people to see also.
Old 09-03-2004, 12:54 AM
20FHK02's Avatar
2002 C230 Coupe
Pic again
here they are
Attached Thumbnails C230 Door Handle Removal Instruction-handle01s.jpg   C230 Door Handle Removal Instruction-handle02s.jpg   C230 Door Handle Removal Instruction-handle03s.jpg   C230 Door Handle Removal Instruction-handle04s.jpg   C230 Door Handle Removal Instruction-handle05s.jpg
Old 09-03-2004, 12:56 AM
20FHK02's Avatar
2002 C230 Coupe
second batch...
Attached Thumbnails C230 Door Handle Removal Instruction-handle06s.jpg   C230 Door Handle Removal Instruction-handle07s.jpg   C230 Door Handle Removal Instruction-handle08s.jpg   C230 Door Handle Removal Instruction-handle09s.jpg   C230 Door Handle Removal Instruction-handle10s.jpg
Quick Reply: C230 Door Handle Removal Instruction
