DIY: M112 Spark Plug R&R
Rating: Thread Rating: 6 votes, 5.00 average.
Old 11-04-2007, 11:02 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
The C240/320 are fitted with twelve (two per cylinder) of either:
Bosch F 8 DPER,
Beru 14 FGH 8 DPUR X 2, or
NGK IFR 5 D 10
MB part number is 004 159 94 03
The C32 has NGK IFR 6 D 10 as original equipment.
MB part number is 003 159 97 03
MB’s spark plug socket, 112 589 01 09 00, helps to make the task easier.
DIY: M112 Spark Plug R&R-sparkplug245wrench.jpg
Have available some anti-seize lubricant and dielectric grease.
DIY: M112 Spark Plug R&R-sparkplugs245paste.jpgDIY: M112 Spark Plug R&R-dielectricgrease.jpg
Raise the hood to its full vertical position. Remove the engine cover and air filter assembly...https://mbworld.org/forums/c-class-w203/116104-d-i-y-v6-air-filter-replacement.html#post1227088
Remove the coil packs. Each is secured with a single #27 TORX fastener.
[DIY: M112 Spark Plug R&R-sparkplugscoilpack.jpg
Use an 18mm open-end wrench on the spark plug wire connector, leveraged against the cam cover, to pull it free of the plug. It helps to reduce the force required by slightly rotating the connector before removing it. Do not place any undue stress on either the sparkplug wires, or the coil pack wires themselves.
DIY: M112 Spark Plug R&R-sparkplugswireboot.jpg
Lay them on the intake manifold.
DIY: M112 Spark Plug R&R-sparkplugscoilpacksoff.jpg
The plugs are now as accessible as they will ever be. To get them in and out is done mostly by feel, rather than sight.
DIY: M112 Spark Plug R&R-sparkplugsbyfeel.jpg
Here's the ratchet, extension, and socket combination used to reach all twelve plugs. YMMV. The plugs nearest the firewall necessitated fitting the socket to the plug first, and then connecting the ratchet.
DIY: M112 Spark Plug R&R-sparkplugs207wrenchcombo.jpg
Use compressed air to blow any residual debris from each plug recess. Remove the old plugs.
Prepare your new plugs for installation by first verifying their gap. Specification is 1.0 mm/.039 inch. While some may argue with the anti-seize step, I’ve used it successfully for three decades. The rationale is merely to lubricate the respective threads. Because the steel plug is threading into aluminum, it’s obvious which is the stronger of the two. No reason to turn a pleasant plug swap into a Heli-coil repair job.
Rub a very modest portion into the threads. Keep it well away from the firing tip so as not to cause misfires. The washer area of the plug should remain uncoated as well, so that it can properly conduct away its heat, thereby helping to avoid pre-ignition.
DIY: M112 Spark Plug R&R-sparkplugs214anti-seize4.jpg DIY: M112 Spark Plug R&R-sparkplugssmashed3-1.jpg
Nevermind about the 'nail!
Place a dollop of dielectric grease on the tip to improve conductivity, and help inhibit corrosion.
DIY: M112 Spark Plug R&R-sparkplugsdielectric.jpg
Thread the new plugs initially by hand to avoid any chance of cross-threading. Because you’ll be compressing a new washer, just get them fully seated on the first attempt. Torque them to 15-22 ft.lbs./20-30 Nm. It will require ~¼ to ½ additional turn to yield the proper reading.
DIY: M112 Spark Plug R&R-sparkplugstorque.jpg
I like to get them snug, then go back to gently sneak up on the correct torque. Go around on all twelve again to establish their final torque and verify your work.
pda1971 (06-09-2018)
Old 11-04-2007, 11:23 PM
mleskovar's Avatar
'17 Jaguar XF
Excellent write up. These pliers make the plug boot removal easier/less traumatic. Getting the boots off the old and on the new plugs solidly was the hardest part for me.
https://mbworld.org/forums/c-class-w203/216797-help-request-spark-plug-replacement.html
Old 11-04-2007, 11:54 PM
Moderator Alumni
TruTaing's Avatar
w203 m112
Subscribed.
Old 11-05-2007, 02:06 AM
Super Moderator
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
awesome DIY John! thanks man!
having you, Ed, John and Jose around really make me feel good about keeping my car past warranty!
BTW, this is going on the DIY sticky.
Old 11-05-2007, 06:04 AM
sstcobra's Avatar
2002 C320 Sedan
John, great write up and photos.
Thank you very much.
Gary
Old 11-05-2007, 06:39 AM
rlee02135's Avatar
2004 C32 ///AMG
great DIY John! this wasn't a fun mod...how much was that MB socket?
Old 11-05-2007, 11:25 AM
BlackLiquorish8's Avatar
C3Twon AWD Jumpofffff
awesome DIY should make it a stickyyy
Old 11-05-2007, 11:46 PM
C230 Sport Coup's Avatar
I"m glad I don't have 12 plugs....
Well it'd be ok if it was C32
Old 11-13-2007, 04:10 PM
Super Moderator Alumni
ScottW911's Avatar
a C32 AMG & S-Works Tarmac
John, you are a stud. Please, keep up your priceless contributions.
Old 11-19-2007, 01:57 PM
uberwgn's Avatar
e300d
I've got to deal with this job soon. SNAP ON offers this tool:
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old 11-19-2007, 02:00 PM
uberwgn's Avatar
e300d
Can anyone offer insight on where to buy one of the OE (Bosch or Beru) plugs? They're not exactly easy to find and appear to be quite expensive when compared to the traditional $1 spark plug.
Thanks.
Old 11-19-2007, 02:04 PM
sstcobra's Avatar
2002 C320 Sedan
Changed the plugs just yesterday....took 2 hours start to finish with the MB spark plug socket. I purchased plugs from www.autohausaz.com. They were $5.43 each.
Thanks for the great write up.
Gary
Old 11-19-2007, 03:01 PM
mleskovar's Avatar
'17 Jaguar XF
Won't work, not enough space around the boot to get the tool clamps around the plug.
Old 11-19-2007, 03:22 PM
uberwgn's Avatar
e300d
Vinyl coated offset jaw tips will pull most domestic and import spark plug boots, including the back plugs on new-model Porsche and Mercedes Benz. Vinyl covered handles are cushioned for comfort.
it's specfically designed for the job. I can't comment directly, but others have used it.
Old 11-19-2007, 03:23 PM
uberwgn's Avatar
e300d
Gary
Gary, do you know the part number of the spark plug they sent you?
Thanks.
Old 11-19-2007, 04:26 PM
mleskovar's Avatar
'17 Jaguar XF
Not on an M112 engine. I guarantee it won't fit around the body of the plug boot. You need something to grab the tip of the boot like:
http://ww2.harborfreight.com/cpi/cta...emnumber=37909
they are also long and provide excellent reach and leverage. I used this plier type and it worked very well.
Old 11-19-2007, 08:19 PM
sstcobra's Avatar
2002 C320 Sedan
Used Bosch plugs #4418. They have 4 electrodes each. I understand the original plugs are no longer made and these are replacements. Car runs just fine....have over 100 miles on the plugs since yesterday.
Gary
Old 11-19-2007, 08:47 PM
mleskovar's Avatar
'17 Jaguar XF
Gary
The standard plugs are still available at about $5.25. I saw no wear on mine after 100K miles, great color. They have the needle/small electrode. The four electrode plug is a gimmick IMHO, or someone please explain the advantage.
Old 11-20-2007, 10:59 AM
sstcobra's Avatar
2002 C320 Sedan
I agree, the four electrodes are a gimmick. I would expect the similar performance versus standard plugs.
Old 11-24-2007, 08:11 AM
uberwgn's Avatar
e300d
The original plugs (listed in OM) are still available and that's what's going back in our car since they've provided 100k miles of fault-free motoring.
These guys have the BERU plug:
http://www.kingsborne.com/
Old 11-24-2007, 08:21 AM
uberwgn's Avatar
e300d
This guy bought the Snap On tool and suggests it worked for him:
https://mbworld.org/forums/e-class-w210/81360-successful-spark-plug-change-98-e320.html
Perhaps the E Class car, which is what I'll be working on, has more clearance than the C Class permitting use of the tool. I guess I'd like to end up with whatever tools make the job easiest and don't result in any damage.
Thx.
Old 11-24-2007, 10:55 AM
mleskovar's Avatar
'17 Jaguar XF
[QUOTE=uberwgn;2518505]This guy bought the Snap On tool and suggests it worked for him:QUOTE]
I definitely won't argue with success....but I don't see how it worked easily. When you actually do the job you'll see what I mean. You'll notice that he also ended up using long handled needle nose pliers to make it work. And I agree with him, removing the boots is the hardest part. It's the same engine in the E so clearance between the boot and valve cover is the same. Trust me, the hose pliers from harbor freight make the job easier. Please let us know how it goes.
Old 11-24-2007, 11:07 AM
uberwgn's Avatar
e300d
m, thanks for your comments. I don't want to invest in a bunch of tools I'll never use again..that's my main concern prior to ordering stuff. If you feel getting those curved jaw pliers is the best option, that works for me. I'm sure I can hit Sears tool store and get those pliers. Would a large version be better than small or vice versa?
Thx.
Old 11-24-2007, 12:35 PM
mleskovar's Avatar
'17 Jaguar XF
..... I don't want to invest in a bunch of tools I'll never use again.....Would a large version be better than small or vice versa?
I agree. The first set of "made for Mercedes" boot pullers I bought wouldn't fit around the boot and I never used them. Somebody on this forum recommended these pliers and they worked very well. The tip is about 1/2" ID and serrated on the inside for grip. You want them long so you can use the valve cover as a pivot point for leverage and it's easier to reach the back boots. They're made by Pittsburgh and you can order them on line from Harbor Freight Tools.
Attached Thumbnails DIY: M112 Spark Plug R&R-front.jpg   DIY: M112 Spark Plug R&R-side.jpg
Old 11-24-2007, 01:14 PM
uberwgn's Avatar
e300d
Thanks, M. Does that Harbor Freight tool have a specific name? They look huge compared to anything I'd have right now.
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
Quick Reply: DIY: M112 Spark Plug R&R
