E-Class (W211) 2003-2009
Plastic trim at bottom of windshield
Old 10-30-2007, 11:48 AM
bigswol2's Avatar
2003 E 500
In trying to replace my Heat exchange shut off motor I'm stuck already. Does anyone know how to remove the plastic trim that shrouds the bottom of the windshield? All of the plastic screws seem to just spin in place and I don't see any other way to remove it. Any help would be greatly appreciated.
Old 10-30-2007, 12:16 PM
Diesel Benz's Avatar
The tasks should be:
- remove wiper system,
- remove multifunction sensor,
- remove the rubber seal from the water collector,
- detach gaskets at the wiper shafts,
- unclip windshield washer nozzles line,
- remove expander clips from water collector, and unclip water collector in the area of the windshield.
Old 11-09-2007, 12:01 AM
WaveyKat's Avatar
Something Slow
am looking to also change the Heat exchange valve on a 2003 E500 hopefully i can get it done with your instructions..
Old 11-09-2007, 01:51 AM
Those changing their heat exchanger valve, search for another post explaining how to detach some of the screws that don't seem to come up but just "rotate free", can use some pliers to take them off.
Old 11-09-2007, 02:13 PM
WaveyKat's Avatar
Something Slow
found this picture on another forum i hope it helps some people when i comes to replacing the Heat Exchanger Valve/Hot Water Valve #211-832-0584
Old 06-12-2008, 02:51 PM
theeddie's Avatar
e55 w/LET TUNE Drinks: vodka STRAIGHT Wheels: 19" HRE 547r Mods:FF headers ASP Pulley
just did this
took about 35 min or so
only problem was the lower clip. was a ***** to get off. i just put a zip tie threw it and yanked. after that all down hill
Old 12-15-2008, 03:33 PM
W Cole's Avatar
makes your daughter horny
bump.. are there any more detailed DIYs out there on exchanging this valve? I will be attempting shortly..
Thanks,
W Cole
Old 12-15-2008, 04:42 PM
konigstiger's Avatar
Received 4,417 Likes on 3,146 Posts
'71 Pinto
Originally Posted by W Cole
bump.. are there any more detailed DIYs out there on exchanging this valve? I will be attempting shortly.. Thanks, W Cole
https://mbworld.org/forums/e-class-w...rol-valve.html
Quick Reply: Plastic trim at bottom of windshield
