rear boot cannot be open
2001 c200k with kleemann pulley
can anyone help ... i make the usual noise but the boot does not pop open ... i tried to use the key but it doesn't work either ... anyone? or should i just go back to the dealer? thanks
not sure if this helps, but my boot/trunk got stuck on my old w202 once and couldnt figure it out until a friend pushed down both ends of the boot lid and then promptly opened it up. Give it a try might work for you!
F10
that worked for me too, that made us 2, so yeah try it.
W203 (2007), W120 (1962)
It is possible that your boot has been locked manually with the metal key.
If the key slot in the lock is parallel to the number plates, it is locked. The boot cannot be opened remotely or using the switch on the driver's door.
It is a little stiff to unlock with the metal key. I had to try for about 15 minutes or so (with the help of some WD40) to get it open. The key slot should be at right angles to the number plate.
Check this out first.
Shan.
Shan.
thanks for ur advices ... tried both didn't work ... may be its the faulty motor ... cos it made the motorise sound but it doesn't pop open ... i did try to use key to open but not successful ... may be time to go to the dealer and get it look at ... cheers
