my 351rwhp baseline dyno with only dusty filters!!
Old 01-11-2007, 01:23 AM
MBworld Guru
FrankW's Avatar
white and whiter
J/K....lol
been on this board for a long time and this is only the first time i dynoed my car. my mods are filters, sl55 splitter, evo odps, exhaust (probably doesn't do crap), and of course the CUSTOM ECU by my ECU guy. SWEET! this is only the first tune (about an hr on the dyno lol) didn't have time to tune it more, will do more tuning when i get more mods. this is making me considering some more stuff to do. lol we'll see. I'm very happy right now.
PM me if you wanna know more about the tuner. lol
best run 351rwhp 353lbft-tq
dyno
air/fuel
Old 01-11-2007, 02:13 AM
SPONSOR
Eurocharged Rick's Avatar
very nice! making good power! whats up with the custom ECU? PM me some info...
Old 01-11-2007, 02:29 AM
jturkel's Avatar
02 C32 AMG
can you also PM me some info about the custom ECU? thanks
Old 01-11-2007, 09:02 AM
SPONSOR
sales@eurocharged.com's Avatar
C63S
Great numbers Frank!!
Something about the graph does not seem right. It appears as if the power is all over the place.
Did they have problems with the car shifting? Did they put a blower on the front to simulate air flow and to assist with cooling?
I have done many pulls on a Dynapak and none of mine bounced around. I think the power is accurate, but something is off.
Here is my last Dyno for your comparison.
Old 01-11-2007, 09:13 AM
Out Of Control!
JamE55's Avatar
Looks good Frank! What's next?
Old 01-11-2007, 10:12 AM
mig888's Avatar
EVE
Translates to nearly ~430HP to the crank on mild mods & tuning . Maybe a bit more fine tuning in the high-end to nip away at this:
https://mbworld.org/forums/c32-amg-c55-amg-w203/176669-c32t-447bhp.html
then get cams and blow everyone else out the water.
Old 01-11-2007, 10:18 AM
mig888's Avatar
EVE
On FrankW's C32 - his last two runs, which were probably his most accurate of the 7 or 8, his peak torque come nearly 1000rpm (okay maybe 5-600 lol) sooner than on your graph. I know - I've felt the grunt!
Old 01-11-2007, 10:54 AM
SPONSOR
C63S
Would you like a cookie for being able to read a graph? I prefer to have more trq in the low end and have it ease into its peak. It seems like he has no power until a certain RPM is reached and then it hits like NOS. I bet it is fun to drive though!!
I'm glad he is able to make that amount of power, but something is wrong. I'm guessing that it might have been shifting issues or it was the tech.
If he does do more mods, he will certainly blow me away!
Old 01-11-2007, 11:17 AM
mig888's Avatar
EVE
Mrs. Fields . Anyway, yes, the lower end of that spectrum had some shifting spikes. You have to look at the last 3 (pink, blue, and yellow) runs for probably the most accuracy - then again, his car was seriously dyno'd 7 or 8 times but STILL quite a consistent car. I stood behind the fans.
Old 01-11-2007, 11:27 AM
mig888's Avatar
EVE
By chance do you have a copy of your A:F readings? It became apparent to me that C32 injectors can be tuned a LOT easier than a C230Ks yesterday - more "give and take" available you can say.
Old 01-11-2007, 11:33 AM
Super Moderator Alumni
drexappeal's Avatar
Midnight Blue 2004.5 C230 Kompressor Sport Sedan. 2002 w210 E320, 2009 w211 E350 Sport
Great numbers for a 1st tune. Can't wait to see how it is after everything is refined and Frank forks up money for new bolt-ons! Your car is gonna go from being a monstor to a freakin' alien, Frank!
Well, I guess I'll have to settle for my car being a sleeper . But seeing your numbers just confirms what I already knew - my car is in great hands!
Old 01-11-2007, 11:34 AM
SPONSOR
C63S
Sure thing boss...
I'm glad that he used the Dynapak, it is a very reliable Dyno. What do you think could be causing the spikes? Did the car shift during runs? Did he dyno it in 3rd?
Attached Thumbnails my 351rwhp baseline dyno with only dusty filters!!-af.jpg
Old 01-11-2007, 11:36 AM
SPONSOR
C63S
Also, do you know exactly what they changed and what the changed items were set to? IE - A/F set to x, Timing set to x, etc.
Old 01-11-2007, 11:43 AM
mig888's Avatar
EVE
Sure thing boss...
Yep, did the dyno in 3rd. Probably the tech just feeling out the car, but you can't "feel out the car" 7 or 8 times and still get consistent numbers - so Frank's car boogies, period... the built Honda guys next to us were like ///AMG.
If you just massaged those A/F ratios down a bit, get it between the 12.0-12.5 ratio for the meat of the powerband, it should probably help - they should have seen that since your first dyno run. See how Franks car just immediately dips into the 12s once the car WANTS it? Amazing, but still a bit more work to do up top (leaning it out) and maybe we'll see a peak drop off even later (with more power). Did he say he still gets 18mpg city, 21-22fwy?
Old 01-11-2007, 11:45 AM
mig888's Avatar
EVE
Also, know exactly what they changed and what the changed items were set to? IE - A/F set to x, Timing set to x, etc.
Now that is proprietary information and what road/dyno tuning is all about.
Old 01-11-2007, 11:54 AM
SPONSOR
C63S
OK, I talk to Renntech about it. They told me once before that the A/F should be between 12.5 - 13 from 4 grand on, but I'll be sure to ask.
I'm getting the same MPG too...sweet!
Old 01-11-2007, 11:58 AM
m444's Avatar
Audi C7.5 S6
Normally on a forced induction car, the magic number for margin is A/F R~12.5,
a higher ratio than this, when under high boost and the chances of detonation are greater. Lower ratios are safer, cooler, but leave power on the table.
The real power, once the AFR is correct, hopefully flat under boost at 12.5 or just under, is in the timing advance. This is trickier on a positive displacement blower, than on a turbo, because of higher boost at low RPM.
Old 01-11-2007, 02:26 PM
SPONSOR
agreed, when tuning a FI car, i like to stay in the 12.0 range, just to be on the safe side...i really wish that i had the capability to tune this car, it is driving me crazy not being able to do this myself...
Old 01-11-2007, 02:31 PM
pshek's Avatar
2003 C-Class Sportcoupe
Get the camshafts and headers Frank, then do the tuning.
Old 01-11-2007, 02:36 PM
jgsx's Avatar
04 C32
I really want a before/after dyno of JUST the camshafts on a stage 2 car . . .
Old 01-11-2007, 02:39 PM
mig888's Avatar
EVE
If anything, Frank's car is only Stage I and pulling these numbers. Ya'll have to hard reset yourselves .
Old 01-11-2007, 03:37 PM
amgmark's Avatar
ML63
Great numbers Frank!! I would be interested in hearing more about the custom tune as well..
Old 01-11-2007, 04:36 PM
MBworld Guru
FrankW's Avatar
white and whiter
thanks everyone for the feedbacks.
I'll have to say the spikes are probably caused by the dyno guy's working out how to use the auto, but the numbers are definitely accurate especially throught the last 3-4 runs which sees 348-351rwhp consistantly.
as far as the torque curve I'm loving the flat torque curve usable for all it's power all the way to redline.
I'll start sending some PM to who requested.
Old 01-11-2007, 04:42 PM
Zeppelin's Avatar
C32
Yeah. Lets have an ECU flash and dyno day at this tuners shop
Old 01-11-2007, 07:01 PM
MBworld Guru
FrankW's Avatar
white and whiter
possibly depending on how many wants to do the tuning.
Quick Reply: my 351rwhp baseline dyno with only dusty filters!!
