Diesel Forum Forum for Diesel engine vehicle related discussion
GT2256V VNT Turbo on an OM617
Old 01-07-2007, 08:36 PM
240D 3.0T's Avatar
1982 300D VNT, 1980 240D 3.0T, 1982 300TD
Pictures-
1: Start of the project. KKK K26 turbo.
2: EGT probe.
3: The stock return tube after it's been cut. The air filter drain hole can be seen behind it.
4: View of the actuator
5: Finished product
Videos: (It sounds much better in person than on my cheapo camera.)
Quick tour around the car. Notice the actuator moving and the intake tube expanding when I revv it.
Some easy driving. Barely 1/3 throttle application.
Full output
Just playing around with it a bit.
Notes-
I cut a bead on the stock intake manifold to keep the tube in place.
The turbo works great as a warmup exhaust restriction (I can see this becoming a problem in the summer).
There is about 2psi of exhaust pressure and just a *hair* off the peg of boost at idle.
There is almost no boost drop between shifts.
EGT's still run in the same ranges. I can easily pass 1250*f.
Decelerating from highway speeds maintains about 6 psi of boost all the way down to 30mph in 4th gear.
The turbo seems hover in the 10psi boost and 10psi exhaust pressure most of the time I'm moving under load.
Boost stays around 8psi : 10psi cruising the highway between 55-75mph.
Max boost is about 11psi below 3500rpm and peaks at 14psi by 4500rpm.
Exhaust pressure at 14psi boost is 20psi. 5psi less than the KKK K26 turbo.
Exhaust pressure can pass 30psi on a hard takeoff and free (no-load) revving.
I will concede that the GT22V is too small for an OM617. EGT's are still excessive at full load.
My main concern is the high initial exhaust pressures (Pegs my 30psi exhaust gauge). I'm worried that it can float the exhaust valves. I don't know at what psi the exhaust valves will lift off their seats.
Attached Thumbnails GT2256V VNT Turbo on an OM617-lmn-gt2256v-1-kkk-turbo-fronts.jpg   GT2256V VNT Turbo on an OM617-lmn-gt2256v-2-egt-probes.jpg   GT2256V VNT Turbo on an OM617-lmn-gt2256v-3-oil-drain-mods.jpg   GT2256V VNT Turbo on an OM617-lmn-gt2256v-7-vnt-actuator-sides.jpg   GT2256V VNT Turbo on an OM617-lmn-gt2256v-8-done-vnt-sidess.jpg
Old 01-07-2007, 09:57 PM
harkgar's Avatar
2006 E320 CDi, 2008 3/4 Ton Suburban, 2007 "rice rickshaw" Accord 5 speed
whats UR target bhp Mr 240?
Originally Posted by 240D 3.0T
Pictures-
2: EGT probe.
5: Finished product
Full output
Notes-
I am not good a DIY guy but really enjoy watching good technicians. What is the purpose of your new turbo? Is it smaller (spins faster) or bigger (spins up slower but forces in more air)? 30 PSI is awfully high. Most passenger car turbos, gas or diesel, do not go beyond 20 PSI. It would be a pity to blow up all that handy work.
Lots of photos please to keep us updated. Videos on U-tube? I can only watch it in my office. Something wrong with my home computer. No sound.
Old 01-07-2007, 10:10 PM
harkgar's Avatar
MB needs an engineer like you 240
Pictures-
2: EGT probe.
5: Finished product
Full output
Notes-
MB builds more reliable cars than BMW and other makes. They did not pay attention to customers but are now forced to with the Japanese hot on its tail. The older (1999 and older) were "chunky" particularly in bodywork and drive train. To please the tree-hugging morons they started to skim by lowering the gauge of steel, replacing steel with plastics and aluminum (paint comes off and rusts). MB engines can take a lot more power and are ideal for souping up.
Carry on the good work.
Old 01-07-2007, 10:15 PM
240D 3.0T's Avatar
This new turbo uses vanes in the exhaust to direct all the exhaust through the turbine. It does not have a wastegate like a traditional turbo. It spools up MUCH faster. THIS video for example shows what I am talking about. In the time it takes the stock Garrett T3 or KKK K26 to build boost to 5psi, I'm already at full boost pressure.
Old 01-08-2007, 11:58 AM
Almost a Member!
BenzDieselTuner's Avatar
Location: Heilbronn am Neckar, Deutschland; Cape Coral, Florida
C123 TurboDiesel - 1985
i see you are posting ur results everywhere. right on!
Old 01-08-2007, 12:05 PM
240D 3.0T's Avatar
Oh yeah. Spread the wealth.
Old 01-08-2007, 09:29 PM
mv420xx's Avatar
thats awesome man...
Old 01-08-2007, 11:57 PM
harkgar's Avatar
Pointed Three site
Tuner,
The Pointed 3 site is very informative and there are lots of interesting postings, particularly on the ULSD.
I am very very close to getting my first MB diesel. Matter of price. Fingers crossed.
Old 01-09-2007, 03:11 PM
Almost a Member!
thats awesome man! check out the diesels and 123 forums on P3 out daily, there are usually some new posts.....
Old 02-05-2007, 03:19 AM
240D 3.0T's Avatar
0-60mph
Now that YouTube has FINALLY got my video active, here it is: http://www.youtube.com/watch?v=uLgEnnQaR54 I do a bit of revving to get the turbo going and I get to 60 at the top of 3rd gear.
Nothing amazing, it's only about 1/2 second better overall. The video I have is 13.6 seconds 0-60 and the best I can get is 13.2seconds. The roads are still cold/wet so I kept spinning the right rear tire every time I tried to do a serious *****-to-the-wall run.
Bandimere Speedway will not be dong it's CSP (Open/Test-N-Tune) races until starting after May-02-2007 (LINK). Sometime after that I'll see about getting an official 1/4mile time slip.
Old 02-05-2007, 06:54 PM
harkgar's Avatar
How important is it to use good oils like your Amsoil if I want to keep a diesel car for 10 years? I read on the "club tdi" site that some people use special 16 wheeler truck oils. Are they any more expensive than synthetics made by Mobil and Castrol?
Old 02-05-2007, 11:02 PM
240D 3.0T's Avatar
I pay about $27 per gallon for my synthetic oil. Mobil Delvac 1. Amsoil is supplied is base oil by Mobil and they add their own additives to it.
Synthetic oil is FAR superior to dino oil. It will significantly slow the wear in the engine and darn near put a halt to timing chain elongation.
IMHO, if you care about your car, you should be using synthetic.
Old 02-06-2007, 09:35 AM
harkgar's Avatar
Delvac oil
Thanks 240.
MB recommends synthetic 0W40 for the 2006 CDi but I do not know how much they are in Toronto. Your price is very reasonable. I have read the term Delvac somewhere before. Is it a diesel specific oil made just by Mobil? What is the viscosity designation? What is the advantage using this particular oil in a diesels engine?
Old 02-06-2007, 11:10 PM
240D 3.0T's Avatar
Mobil Delvac 1 is a diesel specific oil made by Mobil.
http://www.mobil.com/USA-English/Lub...ac_1_5W-40.asp
Quick Reply: GT2256V VNT Turbo on an OM617
