Makin sure the C55/32 Brothas are hooked up on the ECU Reset...IT SMOKES!!!!
2003 E55 & 2014 GL550
Spread the word
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
https://mbworld.org/forums/showthread.php?t=148019
The following 2 users liked this post by Jakpro1:
Doogaloo13 (11-06-2018),
Kuba Sokal (04-30-2018)
1 Post
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Now I know why everytime I re-dyno my car it loses WHP.
I commute to work 70 miles round trip in heavy traffic and this ECU reset before each dyno might give a better measure of my car's true power.
Almost a Member!
Brilliant!! I have had to drive slow and steady the last 2 days because of rain. I thought I was going to have to bring it in to the dealership because there was no kickdown or throttle response unless I floored it. Did this 2 minute fix and I'm back. The ESP kicked on at 50MPH as it shifted (wet road). Now if only we knew the code for the ejector seat and the revolving license plates.
1 Post
C55AMG W203; 330i E90
Look, this is the first time I ever heard something like this. I am certainly going to try it. 28000 km, I have been feeling the car is less and less responsive in the throttle, hopeless kick-down and even the usual top range speed like 170km/h which I now find difficult to get to within a short moment like in the old days when the car was new. I will memorize this procedure by heart. Can't wait to try it. Thanks.
But why a ECU reset will improve the car performance?
1 Post
Right after above post, I tried the procedure, and YES , my car accelerate as like it is back to as it was new again! Sht, without applying much force and attention on the gas pedal, driven it normally, it was always 135 km/h at 5th gear instead of 100km/h !
BTW, for C55, is this effect appling to all M/S/C modes? Or just S/C?
'05 C55 AMG '15 Jeep SRT '11 G37S
Seems a little odd, and I def have my doubts......but I'll give it a shot later on.
If this works, it should be made a Sticky so we don't forget or lose this info!
Originally Posted by Derrick9191
So how often can you do this or should you do this?
1. Can we keep it from reverting back?
2. I've heard that various ECU kits (like the Kleemann ECU and pulley kit that I'm going to get installed in July) give more power, and yadda yadda, but also more linear throttle response. Will the Kleemann ECU revert back like this or stay linear? Will doing this procedure on the Kleemann ECU do anything good or bad or nothing?
Bif
2003 c32 AMG
This absolutely works! Mine was lagging on initial throttle and idling roughly upon start-up. I just did this reset and it is like it was when new. I have to be careful with the throttle again. There is zero lag. I did not even realize how sluggish the throttle had become. Thanks, Jakpro1!
1 Post
1989 Toyota Tercel EZ - dyno'd @ 70whp/77wtq
It seems to work for a car w/ ECU... tried it on my E55, C55 and even my Maxima.... my foot is quite heavy already... so no big difference in acceleration (my certified butt dyno says faster but don't feel it like night and day)... but the shift points are VERY different.
Yes, we should make it sticky....
1 Post
Originally Posted by RizAMG
Just wanted to check, it doesn't reset anything else on the car, does it? Just the throttle response correct? Thanks guys
I did try this yesterday, as well as to my E55 and Maxima.... and boy, I fall in love with all of my cars again
1 Post
Yesterday, I did this 'reset procedure' the first time. I tested the car for about 20 mins though did not get the chance to do more than 130km/h. I did not find any other odd things or anything funny e.g. the headlamps auto on, auto folding mirror were all still working as usual.
I am gonna test the car again today!
Silver 2002 C32, Silver 2006 CLK 350
I did this today and my car didnt shake anymore when I started the car. from the software recall. car was very responsive thanks again guys
Almost a Member!
1997 MB SL320, 2004 Chrysler Pacifica Limited, 2003&2004 Ford Taurus SE/SEL
How do you know if your car has "ECU"? And what is it? Do you think my 97' SL320 has it?
Originally Posted by Jakpro1
Spread the word
Is the pedal supposed to be pushed all the way to the floor...past the kickdown switch/button?
Thanks.
