P0410 cel code on a 2002 c230k
I have searched this topic, and found little info. I know it is a secondary air pump code, and that the supercharger acts as the pump to heat the catylatic converter during start up. I have replaced both o2 sensors (@ 60k miles, I figured they were due for replacement anyways), and checked the hose under the air filter box. I cleared the code, and it comes back after a few starts. Thanks in advance for any help in diagnosing this.
This is a follow up post that may help someone with the same problem. After researching the topic, and basically finding similar responses of 'you need to have special test equipment -take it to the dealer', I diagnosed it in about 2 minutes with no tools at all. I simply removed the hose between the vacuum solenoid, and check valve (the secondary air injection circuit starts just before the throttle body with an appx. 1" hose), started the car and verified that the solenoid was opening for a minute or so, then closing, which it was. Then I attempted to blow through the check valve into the exhaust, and could not. After removing the check valve, I found it clogged with rusty crap. I installed a new check, reset the cel, and haven't had a problem since. Note; the check valve was a pain to remove since it is located between the engine and firewall, threaded (rusted) on and basically part of the exhaust system. I hope this helps.
Sunileeyo (03-19-2021)
I honestly don't get it, why would you go through all that trouble, replace O2 sensors at 60K miles when the Emmissions part of your warranty is 8 years or 80,0000 miles. I love working on my car, finding problems, it's a rush but I certainly wouldn't pay to fix my car when MB will fix it free. I think I responded to 3 posts like this in the past few days, nobody believes me, look in your warranty booklet.....
Now if you are talking about that old beetle throwing obd2 codes, that would be cool.
Almost a Member!
2002 C230
I have a 125k on my 02 coupe and I think thats the problem. There is this werid noise that comes from the exhaust when its in idle. I just made an appt today with the dealer for Thursday although the car is acting really slow. But a few weeks ago I used my friends OBDII and it came up something about the secondary air injection so is this what you had read when you checked your CEL?
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe kid: 2017 GLC SUV
any chance any of you can help with part name/number of the exact "check valve" kazooguy is referring to so I can order it for my car?
Location: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Check Valve
I would suggest taking a copy of this thread, particularly where it says that the check valve is the secondary air injection circuit starts just before the throttle body with an appx. 1" hose,
to a dealership, a good dealership that knows how to find parts.
Give them your VIN # and have them show you the engine schematic for your type of engine. They can blow-up certain portions and pin-point all the parts going from the engine to the exhaust.
Also, see if you can e-mail KAZOOGUY and since he replaced the check valve he must of gotten a part # on the invoice or something.
sorry I can't be of much help.
Carlos
P0410 code
Thanks, Harry
Eddie,
Give them your VIN # and have them show you the engine schematic for your type of engine. They can blow-up certain portions and pin-point all the parts going from the engine to the exhaust.Carlos
Anyone have an idea as to which it is?
Kazooguy, thanks for the info. I have a ’99 SLK230 with a 0410 code I found the check valve on mine and want to replace it. Do you happen to know the part number (I assume it’s the same)? Also I noticed the existing clamps are of a specific type requiring a specific tool. Did you use standard hose clamps when replacing the valve?
Thanks, Harry
Thanks, Harry
2002 C230K, 2013 BMW 328, 2015 BMW X5
I don't know which thread to respond to you in.
Here or https://mbworld.org/forums/mercedes-tech-talk/200555-please-help-part-name-number.html
In any case. The pictures that I took for you, (no-no thanks necessary), work like this.
The Denso part I mentioned appears to be #300. The brass looking check valve downstream is #250.
I'm suprised your CEL doesn't throw your fuel tables/power output. It did mine. Sucked major.
E
E
Thanks E; I guess I see pretty clearly why cross-posting is frowned upon, but I never got much attention here till I posted the other thread in Tech Talk. I really appreciate the photos and hope to get my mechanic working on this soon (again, I'm no D-I-Yer).
nijmegenguy, I hope you're still out there and will benefit from this info as well. Please share your results too.
Here is what I would do if you are sourcing the parts.
Get both, give em to your mech. He can do the brass check valve first. After all, that is what the origional poster was saying had clogged, then if needed, you can do the denso valve.
Good luck, and please do let us know what happens.
E
thanks again; the fax I got from the (dealer) parts guy had the Denso part at $85 and the brass one you identify at $86; I might shop around on the web (at least with the Denso, for which you shhowed the MB part #) to see if those prices are outrageous or not. FWIW, any idea what the other valve, #3 on the parts guy's fax, is?
That #3 part looks to be
003 P/N 0025401497 001 VALVE AIR BLOW-IN ELECTRIC CHANGE-OVER VALVE
http://www.detali.ru/cat/oem_mb2.asp...SGR=120&SGN=04
E
NOT TO PUSH IT, BUT, SINCE YOU SEEM TO BE ABLE TO COME UP WITH THESE PART NUMBERS PRETTY READILY, ANY IDEA WHAT THE p/n OF THE BRASS-looking checkvavlve downstream (#250) is? (please excuse caps lock at the beginning there!)
Sorry, it is not coming up on the sheets that I have. But, you could email Duval your scanned sheet, and they would surely know.
I think the board needs more tech, so this is a good thing.
Sorry I couldn't get that last number for you.
E
E
Here's the drawing from Duval's website, is it one of these parts?
1) Egr valve
2) Egr pipe
3) Vapor canister
4) A.i.r. pump C230 c240 c320
5) A.i.r. pump Insulator
6) Bracket C230, c240, c320
7) A.i.r. pump Clamp
8) Shut-off valve Right
9) Shut-off valve Left
10) Gasket Gasket Back
11) Pressure sensor
12) Hose
13) Hose Connector
14) Hose Joint
15) Valve Changeover
16) Boot
17) Check valve
18) 2.6l and 3.2l Front Right
1) Egr valve
2) Egr pipe
3) Vapor canister
11) Pressure sensor
12) Hose
13) Hose Connector
14) Hose Joint
16) Boot
17) Check valve
Buellwinkle, your diagram looks different than the one MB Parts faxed me. Could you provide me the URL you used? I can't seem to find it on the Duval site.
I found the same diagram that MB Parts sent me at the (Russian?) site emrliquidlife had included, above:
They list part numbers, but their part number for #300 is different than the Denso-labelled unit in e's photo. Their P/N's:
№ Код Замена К-во Вар-т Название Информация Примечания
200 1111403612 001 INTAKE LINE AT CYLINDER CRANKCASE
210 910143008000 001 SCREW AIR INJECTION LINE TO CYLINDER HEAD M8X16
220 910143006000 001 SCREW AIR INJECTION LINE TO CYLINDER CRANK- CASE M6X12
230 915036018103 001 HOLLOW SCREW AIR INJECTION LINE TO CYLINDER CRANK- CASE
235 007603022100 002 SEAL RING AIR INJECTION LINE TO CYLINDER CRANK- CASE
235 007603022100 001 SEAL RING AIR INJECTION LINE TO CHECK VALVE
250 A0021402860 0021406860 - VALVE *006
250 0021406860 001 VALVE (CHECK VALVE)
260 1112381382 001 HOSE FROM SHUT-OFF VALVE TO CHECK VALVE
270 0069973990 001 CLAMP FROM SHUT-OFF VALVE TO CHECK VALVE
270 0069973990 002 CLAMP FROM THROTTLE HOUSING TO AIR SHUT-OFF VALVE
280 000000000812 001 CLAMP HOSE TO BRACKET N 16016-B RS 27/ 15
290 910112006003 001 NUT HOSE TO BRACKET M6
300 0021405560 001 VALVE (SHUT-OFF VALVE)
310 1112381282 001 HOSE FROM THROTTLE HOUSING TO AIR SHUT-OFF VALVE
Eddieo45 thanks for the inputs. I think I’ll start with check valve #250. I looked at e-bay at the following, I asked the guy if this would work for the SLK230. http://cgi.ebay.com/ebaymotors/Air-C...QQcmdZViewItem
I can tell you that E and I compared under the hood and he had a whole extra set of plumbing I didn't have.
His was mfg. 8/2001 and mine 12.2001
Not sure if any of the items above are those Xtra items had by E.
So, there were changes during the year.
Buellwinkle, my SLK230 arrangement looks like the diagram provided by Eddieo45. Where do I find Duvals website showing the emission stuff? I’m still not sure if I’ll attempt to fix this myself (seems like hard to get to) or hang in there for its 50k mile service (5k miles away) when they are reportedly planning to replace the check valve anyway.
