Contour Seats
Old 08-09-2005, 12:49 AM
C240-Merc's Avatar
2017 G63 AMG, 2019 G550
Contour Seats
Does anyone know how to fix contour seats? I am trying to fix the driver's seat and when I press the switches that are located between the seat and the center consol nothing happens and I do not hear anything. Any assistance would be greatly appreciated.
Old 01-10-2006, 04:48 PM
C240-Merc's Avatar
bump
Old 01-11-2006, 06:54 PM
MarcusF's Avatar
2002 CLK430
You've checked the fuse, right?
Old 01-12-2006, 10:39 AM
C240-Merc's Avatar
I can't locate the dam thing. Do you know where it might be?
Old 01-12-2006, 11:43 PM
bazzle's Avatar
Your really a senior member??
I dont know on your vehicle but a good place to look is under hood, in side panels by feet, at end of dash board , in owners manual...
Bazzle
Old 01-13-2006, 12:26 AM
shorthair's Avatar
2014 C300, sport, black/black
According to the manual for my 02, the three fuseboxes are located:
1) On left side of the dashboard visible when the drivers door is open. Not under the dash, but the side. Pull off the cover to acess.
2) On the driver side of the engine compartment near the fire wall under a plastic cover.
3) In the trunk, left hand side, behind a small vertical trim piece that comes off.
Old 01-13-2006, 12:45 AM
C240-Merc's Avatar
I should have been more specific. I know where the fuse boxes are I just don't know which fuse it is. As shorthair descibed I have three and the only one that has a diagram of what fuses are what is the fuse box that is on left side of the dashboard that is only visible when the door is open.
Old 01-19-2006, 06:30 PM
C240-Merc's Avatar
Does anyone know where is electric pump located for the contour seats?
Old 01-19-2006, 11:34 PM
shorthair's Avatar
Found this:
https://mbworld.org/forums/mercedes-tech-talk/114438-contour-seat-doesn-t-work.html
Also, I looked in the dashboard left side fuse area and there was a paper fuse map there. Yours may be missing. Mine was pretty beat up. I have never touched it. Must be from the dealer mechanics using it during the hundred of trips I have made. Here is the map. HTH.
Old 01-20-2006, 01:22 AM
SUNILP's Avatar
2015 E250D
The air pump is below the rear sam in the rear left side of the trunk.
Old 01-20-2006, 11:52 AM
C240-Merc's Avatar
You guys are awesome. Thanks for all of the help!
Old 06-04-2011, 01:18 PM
kcmoc320's Avatar
C320
Originally Posted by shorthair
Found this:
https://mbworld.org/forums/showthread.php?t=114438
Which diagram is this for? The C320 or the C240? I'm following the threads and I'm not sure which this is. I'm looking for the diagram for the 2002 C320. I appreciate any help.
Quick Reply: Contour Seats
