SL/R230: Did a little performance test
s65AMG, sl500
Took the SL out for a little acceleration run.
Acceleration run
without the pictures
It's great, performance is easy to exploit, there are not many cars that you can match (or better) the makers performance figures without any fuss
Acceleration run
Acceleration run
Acceleration run
Looks to me like automatic shifts, consistent shift points plus nice intervention from the traction control at the start.
Thinking hard where I could find a level half mile straight where I could do the same!
s65AMG, sl500
Originally Posted by vantage78
Did you shift by yourself or just let the tranny do it for you?
When I've taken the s55 to the track I use manual selection but often let the box change up it's self and only need to down shift for the next corner, works well.
I do like the colour combination great taste Stephen
The manual shifted to 1st gear at a standstill, then just put my foot down although you have manually selected first the box will change up itself at the redline/it's optimum shift point.
If the traction control was turned off, would the 0-60 been faster?? Any chances of trying this out?
Running your clip and my clip on side by side lap tops, starting as the tacks are sweeping toward 1,000 rpm shows almost identical 0 to 60 mph and 0 to 100 mph times.
You are in a different gear and reving differently at 110 mph ... so you may be pulling away. But it is difficult to see that.
It took me 18 seconds to hit 120 mph. That is when I ran out of road on my local circuit :v .
Is yours a bit quicker to 120 mph?
I for one would like to see the 0 to 120 mph performance of the SL55.
R129, 1999 SL 500, 5 speed automatic performance test:
Will be posted later. Sorry!
Similar performance as compaired to the 7 speed R230.
Almost a Member!
1997 MB SL320, 2004 Chrysler Pacifica Limited, 2003&2004 Ford Taurus SE/SEL
I watched the R129 video compared to the R230 video, and the R129 looks faster to 60 to me!? Is anybody else noticing this?
I counted 4.5 0-60 in the 129?
AlabasterWhiteSL ObsidianBlackML
Dvd Comand
I've heard you can play DVD movies and watch them on your navigation screen...so i tried it and put the DVD into the in dash cd slot and all i got was sound, no picture...and i was in park not moving....if anyone can assist me with this problem it be greatly appreciated
