Dyno of UPsolute chip and Kleemann pulley
W209 - W163
Here is the dyno with the UPSolute chip and Kleemann pulley kit..
Blue is stock > green is chipped > red with chipped with pulley...
40 HP increase....
SLK230
40 HP increase....
SLK230
Re: Which Car?
Originally posted by Wheens
I'm confused. Are the graphs for a SLK230, your C320, or a C230 Coupe?
Also, did you run just pulley alone?
I'm confused too because Kleemann makes a C230 pulley, not a C320 pulley and the stock HP numbers look way to low to be a C320. Vicktorious, is that a C-Coupe or C320 sedan and does Kleemann really make pulleys for the V6 now?
Volvo V90 CC
is thrid gear 1 to 1 ratio?
Why does you graph show hp on 1st, 2nd, 3rd and 4th gears, I thought you could only get true HP on the gear that gives you 1:1 ratio (or the closest to 1:1)??? May be somebody can explain.
W209 - W163
im sorry you guys, i read the thread wrong, it is a C230 Kompressor, i thought it was an SLK230. My apologies once again, here is the thread...
http://www.upsolute.com/cgi-bin/boar...c&f=1&t=000844
1 Post
99' SLK 230 & 01' CLK 430
I also has my 1999 Slk 230 "sport" dynoed at Vadim shop with Kleemann pulley, colder plugs and got 192 hp/ 219 ft.tq. but the engine was running lean. I then installed 4.0 bar fuel regulator and the lean problem solved. I dynoed my car again at Vadim shop and got 184 hp/ 210 ft.tq. WITHOUT any chip !!! That's a saving of $400 !!! I have doubt in Upsolute chip because i try three of their version and it didn't work.
They need to do another dyno with pulley but no Upsolute chip just to see if there's a true gain with Upsolute chip when combine with pulley.. The dyno sequence should be ..
1) Stock
2 Pulley
3) Pulley & Chip
1) Stock
2 Pulley
3) Pulley & Chip
