Broken Wing Mirror Mount:(
Hi all -
Looking for advice on removing/replacing the wing mirror mount.
I was washing the car (99 C280) couple weekends ago, and I bent the mirror housing slightly left/right (as I usually do) to let the water run out - and cracked the mount which secures the wire tether holding the mirror housing in place.
I was able to remove the three screws holding the mount on the door, but not the two plastic multiway plugs for the mirror motor and (I assume) the autodimming feature.
Does anyone know how to or the trick to remove these multi-way plugs without Serious Damage to the connectors???
thanks...rich
thanks...rich
1 Post
11 ML350W2 / 17 GLC300
Are you sure you cracked the mount? I did what you did and broke the spring hanger finger off of the mount. I didn't have time to work on it and my wife took the car to the dealer for repair. They replaced the mirror assembly - about $450 + labor. They returned the old mirror assembly to me and I then was able to create a new spring hanger mount with a screw and epoxy. I have that mirror as a spare for when I break this one. My question now is how to take the plastic cover off of the mirror? If I can take that off, I can repair the mirror.
Jim
Jim
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Re: Broken Wing Mirror Mount:(
thanks...rich
thanks...rich
You can buy a stock mirror assembly for pretty cheap either here or off eBay. I can provide you with one if you can't find it.
You can also upgrade to W210 model update mirrors, with blinkers. If you don't want to go through the hassle of hooking up blinker wires, you can just plug them in and they will work as your old ones, without blinker. These are relatively cheap too, and update the look of your car.
-s-
Jim
Jim
-s-
