VIBRATIONS 70mph+
Old 08-09-2008, 02:28 PM
benz_addict's Avatar
V12TT
VIBRATIONS 70mph+
I have a 4Matic S500 with 245/40zr19 front and 275/35zr19 in the rear (S65 tire sizes). My car has really bad vibrations on highway speeds. Dealer found a bent rim (front right) but they fixed it and vibrations still happen. I got them rebalanced about two months ago so I ruled that out too, now I just don't know what's causing it? I also have brand new Falken tires. Is this because I have a staggered setup on a 4matic?
Vibrations don't happen with my stock 17s.
Old 08-09-2008, 03:18 PM
Skylaw's Avatar
2005 S500 4-Matic, 1978 450SL
Don't Use Staggered Wheels On a 4Matic
I don't know if it is the cause of your vibrations, but suspect that it is. NEVER stagger the wheels on a 4Matic, unless you can ensure that the rolling diameter (revolutions per mile) of the front and rear tires are the same. You will wreck your drive system.
See http://www.benzworld.org/forums/w220...ml#post2826116 and the diagram at post 12, https://mbworld.org/forums/showthrea...hlight=4-Matic. When you can see that all of your drive shafts and transmission are linked, with only CV joints to account for differentials in rotation, you'll see what I mean.
The vibration could come from other sources - ball joints, other front suspension components often written about in the forums. Staggered wheels on a 4Matic, without taking the precautions I mentioned, is a prescription for HEAVY repairs.
Old 08-09-2008, 04:14 PM
Gondon's Avatar
02 S500 Sport
Control Arms can cause this vibration?
Old 08-09-2008, 04:24 PM
V12TT
rims are off the car now, they'll be up for sale.
Old 08-09-2008, 04:36 PM
AH1W-COBRA's Avatar
2003 S500, 03 C240, 03 E320, 03 tahoe
the rims are fine?
it was simply the zr-45 and zr-35 mis match.was this required because of the 19 inch wheels or simply cosmetic.all you need is two tires right?oops,didnt look closely enough at your thread.no problem with 17s.bent,stagger or bad tire at least your drivetrain is breathing a sigh of relief.
Old 08-10-2008, 12:41 AM
Dino I's Avatar
2005 S500 4Matic
Skylaw, you're absolutely right about the rolling diameter. If you do the math, you will find that the eight of the flank for the front tire is 98mm and the height of the flank for the rear tire is 96.25mm. The respective diefference in distance per revolution is approx. 1/2 inch. That is sufficient for the 4Matic (together with all the other wizards - e.g. 4ETS) to engage, and that is what is causing the vibrations. In the long run, this will, as Skylaw already pointed out, ruin your car.
For RWD cars this doesn't matter, because the ASR verifies only the rear RPM's and the ABS is not triggered by this little (and - per axis - balanced) difference.
So, to just chime in - DON'T DO THIS TO A 4MATIC, IF YOU WANT TO KEEP IT!
Old 08-10-2008, 02:41 AM
V12TT
thanks for the tips guys
Already sold the wheels LOL
Old 08-10-2008, 09:52 AM
Skylaw's Avatar
Thanks, Dino I.
I drove Audis with Quattro drivetrains for years. Nothing sadder than seeing a new one in the shop one day, on a lift with its drivetrain components spread out all over the place. I asked the tech what was going on - the tech said "This guy didn't believe his manual when it said don't drive more than 50 mph or 25 miles with the emergency (small) spare tire. Damage is over $10K, including to his transmission." It had happened after about 100 miles of driving.
I always made sure I had a full-sized spare in my trunk, and always replaced all 4 tires at the same time when they needed it. Plus, I was a bear on checking for proper inflation.
And that was before the Audis had sophisticated stability control systems, to the extent our Benzes have today.
Old 08-10-2008, 09:28 PM
newton22's Avatar
BMW E39
Thanks, Dino I.
I guess Porsche utilizes a completely different AWD system as all their AWD cars run staggered sizes.
Old 08-11-2008, 12:14 PM
Dino I's Avatar
2005 S500 4Matic
newton22,
although, I don't know any specifics of the Porsche system, there is nothing against staggered wheels, as long as you make sure that the rolling diameter is the same on both, front and rear. It is all about different speeds (rpms) of the tires...
Old 08-15-2008, 03:07 AM
V12TT
Have a question...Not that I have the wheels or I'm going to do this but JUST ASKING because it's really been on my mind before I sold my wheels anyways,
What if I went 255/40zr19 all around? Same tire size all around? The rims were 8.5" front, 9,5" REAR. Would that affect the 4matic system?
Old 08-15-2008, 09:18 AM
newton22's Avatar
BMW E39
In theory, it should work, but I'm not so sure. In reality, it would look horrible, as the rear tires would be stretched and the fronts would be slightly bulging out.
Ideally, get 8.5s all the way around and run 245/40-19, my current setup.
Old 08-28-2008, 08:06 PM
ebolick's Avatar
2000 S430, 1999 E 320, 2 K5 blazers,
hope this does not sound to dumb but how do i know if my car is 4matic? i hope not since i have stagger rims on it. and i have had alot of suspention problems and now my trannie is slipping a little bit from 2 to 3 gear.
Old 08-28-2008, 10:13 PM
my06clk's Avatar
04 S430 (sold),05 X5 4.4i, 02 325i, 87 560SL, 85 Alfa Romeo
+1 to that
Old 08-28-2008, 10:16 PM
my06clk's Avatar
4matic means your car has all wheel drive. The quick check it to see if you have drive shafts on the front wheels. If not its a RWD car.
Wheels won't make a tranny slip.
Old 08-29-2008, 12:08 AM
S-Clusiv's Avatar
Whatever there's gas in...
were there MY2000 4Matic S-Classes?
Old 08-29-2008, 12:29 AM
newton22's Avatar
BMW E39
To my knowledge, no.
Old 08-29-2008, 06:45 AM
Skylaw's Avatar
According to the MBUSA older model overview, 4-Matic was first offered on the W220 in the '03 model year.
Old 08-29-2008, 12:02 PM
ebolick's Avatar
thanks since mine is a 2000 i dont have to worry
Old 08-31-2008, 12:52 AM
Dino I's Avatar
2005 S500 4Matic
4Matic (AWD) started on the W220 with MY2003 as already stated.
You can check whether it is a 4Matic by looking at the VIN...
S500 RWD VIN starts with WDBNG75...
S500 4Matic VIN starts with WDBNG84...
S430 RWD VIN starts with WDBNG70...
S430 4Matic VIN starts with WDBNG83...
The S350 4Matic was not offered in the US.
All other W220 models were not available with 4Matic.
Corrected thanks to Skylaw
Old 08-31-2008, 07:43 AM
Skylaw's Avatar
Originally Posted by Dino I
All other models were not available with 4Matic.
Correct, if you mean only "all other W220 models" (e.g., S55, etc). The E-Class has offered 4Matic for many years.
Old 09-01-2008, 02:34 PM
Dino I's Avatar
2005 S500 4Matic
Corrected the statement regarding all other models thanks to Skylaw.
btw, the 4Matic-equipped models always come with the 722.6 transmission (which is the older 5speed transmission), whilst the respective RWD models come with the newer 722.9 (i.e. 7speed) transmission (S430, S500) starting in MY2004. This results in an even higher mpg for the RWD models in comparison to the 4Matic models (amongst other things).
Old 09-01-2008, 03:50 PM
Skylaw's Avatar
Helpful info in both of your posts, Frank. Thanks!!
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: VIBRATIONS 70mph+
