cabin air filter replacement
Old 03-13-2007, 01:43 AM
blkgem1300's Avatar
2000 s 500
i have a 200 s 500. how do you change the cabin air filters.
Old 03-13-2007, 10:48 AM
Singularity's Avatar
2005 S500 4matic
Exclamation
Replacing Heater/Ventilation Dust Filter
  1. Glove Compartment
  2. Locking Slide
  3. Cap
  4. A/C Housing
  5. Dust Filter
  1. Remove glove compartment (1)
  2. Unlock locking slide (2) upwards and remove cover (3) from A/C housing (4) in the direction of the arrow3. Pull both dust filters (5) out of the A/C housing (4)
  4. Install in the reverse order
NOTE: Dust filters (5) must not be cleaned but housing (4) should always be replaced. In order to prevent contamination of the vehicle interior, hold dust filters (5) horizontal when removing.
Replacing Activated Charcoal Filter
  1. Remove right cover below instrument panel
  2. Pull back right front floor covering
  3. Move locking slide (2) in the direction of the arrow and remove cover (1)
  4. Remove both activated charcoal filters (3) downwards out of the AC housing
  5. Install in the reverse order.
NOTE: Activated charcoal filters (3) must not be cleaned but should always be replaced.
The following 2 users liked this post by Singularity:
Fried Chicken (02-05-2024), R3504Matic (04-15-2024)
Old 03-15-2007, 03:34 AM
blkgem1300's Avatar
2000 s 500
wow! thanks a lot
Old 04-11-2008, 02:36 PM
tn52's Avatar
2006 S500 AMG Package, 2023 GLE 450
More instructions to remove the glove box please (S class)? there are several black plastic covers in there and I am not sure which ones to pry off. Any special tools so I will not break them? Thanks.
Old 04-12-2008, 03:02 PM
bamberger_1's Avatar
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
Two on the top and two on the bottom of the gloves compartment,right in the front. Behind the covers you'll find screws.
Old 12-29-2009, 09:17 PM
alfa's Avatar
ML320 former CLK230 kompresor (euro specs) and BMWe39
let me add a some more tips
1. when you remove the console box assembly be careful not to damage the small clip on the top middle portion beside the lamp assembly. It holds the cable release for the door
2. After removing the screws the whole console has to be pulled out with a gentle force
cheers!
Old 12-30-2009, 07:03 AM
MRAMG1's Avatar
S600, GL450, Audi A5 Cab
Autozone, or most larger auto part stores stock these cabin filters for $20 each, you need two. Filters are VERY easy to replace, charcoal a little harder. Did mine a few months back. They even came with instructions
Good luck
Old 04-14-2010, 01:44 PM
MRAMG1's Avatar
Just did the charcoals this weekend. Bought them from Ebay for $55. Although they did not look as good as OE they fit perfect.
Took about 20-25 minutes.
Thanks guys for the instructions
I just loved the MB instructions, pull forward to pull back. But the funny part is, they were right
Old 08-31-2010, 12:00 AM
ksersoze's Avatar
2002 CLK 320, 2000 S430, 2004 Lexus GS300
Need help with glove compartment removal
I disconnected and removed the lamp assembly. I then unscrewed all four screws (2 in front and 2 from inside top). I tried to pull the glove compartment assembly, but it seems to be catching on to something on the left side or bottom. Do I need to remove the knee protector panel below the glove compartment before it would come out? Is there anything else I need to remove or disconnect before the glove compartment slides out? Thanks in advance for the help!
Old 07-31-2011, 06:25 PM
dweb4's Avatar
S550 4-matic
I replaced my filters on 05' 430 thanks for directions worked just as posted. And the unfounded smell when blower motor runs has gone away as well must've been filters I was done start to finish in 20mins, compared to my acura which took 1hr and half. MB all the way...
Old 07-31-2011, 10:07 PM
Quadcammer's Avatar
96 and 08 911 turbos
When you say the ones in the "front", do you mean the screws with the rubber bumpers? If so, those are just adjusters for the glove box door.
If I recall correctly, there are two screws on the bottom of the glove box.
Also, remember to disconnect the cable for the glove box door latch.
Old 08-01-2011, 12:17 AM
benzat17's Avatar
2003 S430
there is also two screws on the top side they look like rubber screws you need to take off.. i know there is a youtube vid about it let me look for it
Old 08-01-2011, 12:18 AM
benzat17's Avatar
2003 S430
http://www.youtube.com/watch?v=ASMwq1zim-k
here you go that should help
Old 02-04-2024, 10:55 PM
mikeyflowerguy's Avatar
2008 ML320CDI, 2012 ML350 Blutec
I am stuck at the same spot...luck, the glove box assembly has some give...I'm unlikely to change the cabin filters in this fashion again....gonna go through the dust filter assembly under the hood
Quick Reply: cabin air filter replacement
