2001+ owners ONLY: What problems have you had with your W210?
Old 03-17-2006, 02:36 PM
mbr129's Avatar
'03 BMW 330i ZHP / '06 Volvo V70R
I'm looking at potentially buying a 2001+ E320 4-Matic wagon. I read the MY2000 cars had a lot of issues. I'm trying (with your help) to isloate the 2001+ cars and see how troublesome they have been.
Please list your experiences on your MY 2001+ W210. Thanks!
Old 03-17-2006, 02:54 PM
RobertG's Avatar
things with and without wheels
Catalytic converters rattled- replaced
Old 03-17-2006, 04:04 PM
RickyE430's Avatar
2001 E430 Sport
Cat's and Display replaced
Old 03-17-2006, 04:27 PM
mbr129's Avatar
Hmmm... these cats seem to be the running theme so far. Is there a recall for these? I assume they are big $$$.
What do you mean by display? Instrument cluster display?
Old 03-17-2006, 04:53 PM
RickyE430's Avatar
2001 E430 Sport
Yes, instrument cluster display. Cat's were replaced under emmissions warranty( 8yr, 80K)
Old 03-17-2006, 04:56 PM
mediasteam's Avatar
2001 E320
Catalytic converter replaced on my e320 2001, everything else seems to be fine.
Old 03-17-2006, 05:59 PM
RobertG's Avatar
Cats can be expensive if youre buying OEM or you can get aftermarket for a lot le$$
Old 03-17-2006, 06:02 PM
mbr129's Avatar
Thanks guys. So far, it seems pretty solid. I guess most of the issues must have been ironed out by 2001.
I'll just be sure to ask re: the cats if I end up going this route. My wife wants a 2005 Outback LL Bean, but I rather get the E320. I'm sure I can convince her.
Old 03-17-2006, 06:20 PM
RobertG's Avatar
since youre looking into the 4-matic use the search feature for anything involving that, my e-320 exceded my expectations so far.
Old 03-17-2006, 07:11 PM
kudkudniyog's Avatar
2008 X164 GL450
Cat and evaporator
Old 03-17-2006, 07:13 PM
RobertG's Avatar
you had an evap go?
how much did it cost you ?
Old 03-17-2006, 07:16 PM
2008 X164 GL450
Originally Posted by RobertG
you had an evap go?
around $4300.00 installed at a local MB dealer
Old 03-17-2006, 07:18 PM
RobertG's Avatar
ouch!
Old 03-17-2006, 07:33 PM
platinumsc's Avatar
2006 Lexus GS300, 2007 Lexus GS350
For a history of issues, check out www.lemonmb.com
Old 03-17-2006, 08:43 PM
Richard / E320's Avatar
2001 E320
I replaced the battery at the 4-year mark, but that was due to my error. Nothing else but normal maintenance.
Old 03-17-2006, 10:00 PM
mbr129's Avatar
Great, Thanks!
Old 03-17-2006, 10:03 PM
raymond g-'s Avatar
99 E320
TroubleBenz
AllData - technical service bulletins
Old 03-18-2006, 10:20 AM
slk55lvr's Avatar
I have an 01 e430 4matic that had the following items replaced over the past two years:
Steering angle sensor
Maf sensor
Oxygen sensor
Sensor for exhaust (not sure of the name)
The total for these repars was about 2500-3000. Since then she's been good, but I do have to add a qt of oil every 2500 miles.
Old 03-19-2006, 11:42 AM
atul's Avatar
2013 E350 4matic Wagon, 2002 E320S4 - E-class W210 Wagon 4-matic
Catalytic converters replaced on my 2002 E320 at 45K miles. Covered by Starmark extended warranty. But I had a lot of trouble convincing the dealer that something was amiss with the car. You can read the saga at http://mbca.cartama.net/showthread.php?t=8519. I first thought this the symptoms were caused by a bad transmission, but it turned out to be clogged cat converters.
The display in the instrument cluster is beginning to act up. I guess it is time to replace that too.
Old 03-19-2006, 01:10 PM
Little's Avatar
2001 E430 4matic
My '01 E430 4-matic problems to date in my 25,000 miles of ownership. I bought the car with 27,000 on the clock.
Items repaired so far:
1. Instrument display
2. Speedometer sensor (speedo would stick and then pop)
3. Bad steering squeak (unfixed)
4. Mass air meter
5. A radio problem, radio stays on for 20 seconds after key is taken out (unfixed)
6. Passenger Seat Pad sensor (unfixed)
7. Driver's side rear window regulator failure
7. Today's new problem, crank but no start
8. Ticking engine
Once all is repaired under my extended warranty after this next fix, she's up for sale.....
Old 03-19-2006, 02:36 PM
mbr129's Avatar
Hmmm...
So are the cats a mileage issue befor ethey clog/fail? Is it due to a defective cat and the new ones last longer, or would replaced cats clog/fail prematurely again?
Old 03-19-2006, 05:09 PM
RobertG's Avatar
cats dont clogg , they rattle
Old 03-19-2006, 08:09 PM
mbr129's Avatar
That's what I thought. atul (post above) says his were clogged though. It does seem that the chronic probelm is the rattling, from what I've read.
Old 03-19-2006, 08:22 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
My 01 E320 4Matic has been gone for a year now and replaced with an 05. I had the W210 since new in 2000 and the only item that comes to mind was the replacement of both Cats under warranty. Otherwise the car was excellent as is my W164 and for that matter my 06 ML500.
Old 03-19-2006, 08:45 PM
mbr129's Avatar
That's great to hear. It really seems like for the most part it is just the cats.
I really would go for it and buy a new E350 4Matic (or better yet a 320 CDI 4Matic wagon if they offered it), but we are going to put so few miles on whatever wagon we get that I just can't justify that level of depreciation (Less than 8K miles a year for sure). So I rather get a 2001-03 E320 wagon and keep it for 3-4 years and then pick up another lightly used E-Wagon. We'd only use it for errands, snow conditions, and family trips.
Quick Reply: 2001+ owners ONLY: What problems have you had with your W210?
