Sign in using an external account
| Home | Register | Photos | FAQ | Members | Insurance | Search | Today's Posts | Mark Forums Read | Cars | Garage | Vendors | TSB & Recalls |
| CLK55 AMG, CLK63 AMG (W208, W209) Discuss the past, present and future CLK55 AMG and the CLK63 AMG. |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | ||
Drives: 04 CLK55, IWC CLS55 AMG(one of 55), 07 Honda CR-V 4WD
Evosport! Help me~
#2 |
Drives: C32 AMG
OK, the install is pretty simple. You just replace factory parts with ours. Alternator usually needs an air gun to brake loose the nut that holds alternator pulley. Water Pump pulleys is simple four bolt bolt on. Power steering will need a pilley puller that is very common mechanics tool.
If your mechanic still has questions have him call on Monday - 714.901.3100. |
#3 | |
Drives: W210, W220, W163, W164, C6
Quote:
I emailed my buddy in the local Boston area to forward me the contact info to who installed his Evosport pulley kit...I'll update you with his response.
__________________
2001 Brabus E430 2001 Lorinser ML430 2002 S500 Spt. Ed 2007 Brabus ML500 2007 Town & Country Limited 2005 C6 Corvette 434 LSX Twin Turbo - 1118HP/971TQ 2009 R35 GT-R....coming soon |
#4 |
OK...my buddy was quick to response!
Victory Automotive Peabody, Ma. 978 - 535.2780 Contact: Mike (owner)
__________________
#5 |
thank you very much for your help.
#6 | |
Quote:
__________________
#7 |
Drives: 2003 CLK55
Just out of curiosity...how much is it to get the pulley installed?
__________________
1999 CLK430 Black/Black(Gone) 1999 ML430 Black Opal 2003 CLK55 Black/Black
#8 |
Drives: 03 CLK5.5 AMG
under drive pulley set,Install
Just for Grins , I installed a set of these pulleys on my 03 CLK 5.5 AMG. I did check the Quality of the workmanship ,, So I put them on the Lathe and found them to be very straight , no wiggle. Precision made and too within .0005 And Thats Excellent!
The installation was pretty straight forward , A little bit of a pain ,because I left the alternator mounted to the engine and No removal of assys.. The alternator pulley nut was on TIGHT!! It took a strap wrench and a 24"breaker bar too get it loose . Once that was done , the pulley slid right off the stator winding shaft. The water pump pulley is a no brainer!!. The Power steering pump pulley , removal & install is touchy?? To do this part of the JOB right , you will need a K-D Tools , Pulley remover/ installer Set. Part Number K-D 2897 . I brought mine at the local NAPA store . Expect to pay about $83.00 Or Borrow one. This kit works the best.I looked at several types & Manufacture of R & R Kits Snap-On , Mac . The K-D fits better and will not damage the OEM or the EVO pulley. Sometimes the auto parts stores have a loaner / rental tool program. This part must be done Right!! Remember it is a poly vee / serpentine type belt and must have perfect pulley alignment. Or you will throw the belt on short order. The job took about 3 hours, a beer break .and 2 scraped knuckles. Can be done on any Saturday afternoon I then dynoed the car. I picked up about 8 hp in the mid range , but only 2 hp above 5000 rpm Was it worth it YES!! I will take the increase. A Hp here , a HP there adds up at the day. It's tough to measure the rate of acceration on the Dyno. I just had to remember that this motor does not always respond with BIG inprovements , like the claims made for American built engines. You can race DYNO' all day long, But the history is made at the track Last edited by PTE; 04-09-2006 at 11:56 AM. |
| Tags |
| automotive, e430, evosport, kit, mercedes, ml500, peabody, power, pulley, pump, removal, steering, victory, w209, water |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Dyno run with Evosport Stage 1 + SL55 intake | TC32AMG | C32 AMG, C55 AMG (W203) | 13 | 09-24-2004 11:22 AM |
| ASE chip, Evosport ODPS | amgc32 | C32 AMG, C55 AMG (W203) | 23 | 07-04-2003 01:49 PM |
| Evosport July Special | Mach430 | C32 AMG, C55 AMG (W203) | 36 | 07-03-2003 07:04 PM |
| Evosport July Special | Mach430 | CLK-Class (W208) | 1 | 06-20-2003 05:29 PM |
| evosport Intercooler and Pulley upgrade news .... | otoupalik | C32 AMG, C55 AMG (W203) | 8 | 09-29-2002 11:45 PM |
