| Home | Register | Photo Gallery | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Used Cars | Vendor Directory |
| C32 AMG, C55 AMG (W203) Discuss the C32 and C55 AMG. |
| Welcome to MBWorld.org! |
Welcome to MBWorld, You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today! |
LinkBack | Thread Tools | Search this Thread | Rate Thread | Display Modes |
#1 | |||
Drives: 02 C32 AMG sold!
dkflipse's C32 on Mustang Dyno w/19" wheels: 352RWHP & 361RWTQ!
__________________
LET Motorsports ECU LET Motorsports Heat Exchanger ASP pulley 178mm - 18.5psi Code 3 Intake w/K&N Filters NOS Dry kit - 25shot Dynotune Nitrous Digital Boost Gague 12.662@109.81 at PBIR on 4/FEB/09 02 C32 SOLD! In the hunt for a W211 E55 |
#2 |
Drives: C32 AMG
And your IAT's: (Mine are lower than yours BTW ) You're cooler than I am! Thanks for posting the pics. I've been trying to figure out hot to do it for the past 2 hours!
__________________
Renntech Stage I, Y-Splitter, H&R Springs, 352 RWHP/361RWTQ http://forums.mbworld.org/forums/sho...69#post2565669 |
#3 |
No problem. I gotta send you the full package, pics of the car, videos, datalogs, etc..etc..
__________________
#4 |
Drives: C43, SLK32, CLK63 Black Series
This car is running great. Very nice A/F. I'm struggling with a A/F fuel problem on my SLK32. I think the fuel pump is the weak point. SLK32s run out of fuel system capacity at about 350 hp. C32s don't seem to have this problem. SLKs have slightly larger injectors and use an external fuel pump. The C32s use a fuel pump that is in the gas tank.
#5 |
Drives: C32
At 6000rpm my car makes 50 more horsepower than yours
#6 |
Drives: GMC
IIRC, you and I have previously discussed your potential fuel delivery situation. Have you read its pressure at the rail during WOT runs/tests? Only reason I ask is because the external pump is so easily upgraded. The C contingent is SOL without a substantial expenditure.
http://www.weldonracing.com/index.phtml If you do indeed have sufficient volume and its commensurate pressure, then perhaps it’s a DME tuning opportunity that is next on the agenda. |
#7 | |
MBWorld Fanatic & SPONSOR
Drives: ...
Quote:
you can watch the car go from 12:1 A/F to 15:1 A/F in an instant right at 1.4 bar of boost...just food for thought...i am working on the tuning issue |
#8 |
Nice numbers
now track it!
__________________
LET 185mm+Custom Tune+SL55 full/Ventus Evo/19" Bremmas C32 OEM pulleys F/S http://www.mbworld.org/forums/engine...ml#post3194242 Newbie search http://mbworld.org/forums/showthread.php?t=201140 Kenwood DNX7100 http://mbworld.org/forums/showthread.php?t=233993 Buyer/Seller ratings thread: http://www.mbworld.org/forums/c32-am...ng-thread.html LEARN TO PLAY MYSPACE MOBSTERS BETTER PM ME |
#9 |
dkflipse, what kind of wheels are those?
#10 | |
Quote:
The reason why I think it is a pump or injector problem is that after I had my headers made, the car leaned out. I had it reprogrammed to add 10% more fuel through the entire RPM range. It worked at the lower RPMs but at 4500 rpm and higher, adding more fuel didn't have any impact on the A/F. The car ran the same as it did before the reprogram. I don't have a wideband O2 on the car. All of the A/F data was captured using a tailpipe sensor on a dyno. I haven't seen anything near 15 to 1 using the tailpipe sensor. I'll email you the before and after program data. Maybe you are right and it is a tuning issue. I hope it is. |
#11 | |
Drives: ...
Quote:
#12 | |
Drives: SLK32
Quote:
you could be right. When they made the official increase of the speed-limit up to 280 KM/H at AMG in Affalterbach/Germany on my SLK32, they also changed the fuel pump into a bigger one. They said it is neccessary because the normal fuel pump is at its limit, especially when you drive faster than 250 KM/H for a longer period. When you rise the speed-limit of a C32 at AMG/Germany, you don't have to change the fuel pump. The C32 has, as you said, a different fuel pump. Hope that helps. Kind Regards from Germany Bruno |
#13 | |
Quote:
#14 | |
Registered User
Quote:
#15 | |
Quote:
#16 | |
Drives: ...
Quote:
sorry for complaining about the tuning Adam, my mistake... |
#17 |
Drives: C32 AMG
Fellas - go find you're own thread
__________________
#18 |
__________________
#19 |
Drives: C32 AMG
What the hell you doing up so early -
__________________
#20 |
Drives: 2004 C32 & 1993 RX-7
I gotta work today and tom. And I dont work at Starbucks
#21 |
Rude awakening this morning
![]() Sorry to hear, but I get to close 5 days out of the year, and you damn could bet it's the holidays.
__________________
#22 |
you are teling me
most places that have 80 degree weather on Jesus' birthday is usually a tropical island, resort, or cruise ship. Not in this third world country we know as the banana republic |
#23 | |
Drives: SLK32 AMG
Quote:
CrossFireForum : "I finally got the specs on the SRT6 injectors from my SPY at Bosch I must say, they have a HUGE flow difference from the NA engine and now I have to figure out how the SC engine is regulating the flow, whether by pulse width or pressure regulator. NA ENGINE: 17 lbs/hr at 3.8 Bar, or 55 psi/ 14.5 ohms. SC ENGINE: 51.6 lbs/hr @ 55.1 PSI / 14.5 Ohms based on 380 kPA = 3.8 bars = 55.1 PSI " |
#24 | |
Drives: SLK32 AMG
Quote:
51,6 lbs/hr * 55,1 psi = 541,8cc ???? 450 cc ? |
#25 |
A guy on the r170 forum had his injectors flow tested and reported that they are 450cc. He is having them enlarged.
http://www.benzworld.org/forums/r170...rojects-5.html And well not really relevant to the C32, here is a link to a new thread more more details on the SLK32 fuel system. http://www.benzworld.org/forums/r170...-projects.html |
| Tags |
| 700228510, a0014704794, amg, c32, car, dkflipses, dyno, stage |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Display Modes | Rate This Thread |
